So I'm looking to replace my front shocks on the 147 I've seen a set but they are for the GT I'm I right in thinking they are the same through the GT 156 and 147 range.. The company advised spring are different?
thanks for the advise im pretty confident the setup will work perfect.. ive done few setups similar in the past for my track carsI'd be very wary of fitting suspension components to the front, which are not identical to those on the rear - springs and/or shocks.
You run the risk of compromising the handling, especially cornering.
£155 for a full set of springs & dampers........... :thinking:Why does that brand name ring a bell .. and says avoid? Read something somewhere about the harsh ride you get.
OK so it this car for the track or road? Two completely different scenarios ...thanks for the advise im pretty confident the setup will work perfect.. ive done few setups similar in the past for my track cars
