1 - 11 of 11 Posts
"It failed on the headlight aim being too low on both lights, missing mounting on the exhaust. excessive play in the trailing arm pin/bush and excessive CO after the 2nd fast idle"
Hopefully nothing a hammer and some gaffer tape can't fix :lol:
I expect the headlights are fairly simple to rectify (or is there something that often breaks?)
Exhaust mounting and suspension bush seem straightforward.
Excessive CO - lambda sensor?
Oh, and the aircon doesn't work and the engine rattles like a diesel. But hey, I expect it will be a good introduction to the mechanics of a 2.0TS :)
Wouldn't it be funny if the low lights was due to the regulator being set for a heavy rear load... :rolleyes: Could also be that it's stuck in that position. Have you checked?
Good luck in getting is sorted :thumbs: ... how much did you pay for it??
Discussion Starter · #6 ·
P reg (presumed 96) and 112k. Some history including cambelt at 82k. Owner knows a bit about Alfas as he reckons the diesel rattle is the variator.
I've already bought new genuine variator + belt tensioner, just need to start collecting the rest of the service/MOT fix parts. Oh, and collect the car of course ;)
Administrator
Good luck - '96 is one of the first and at 112k it will need some stuff.
Good that the cambelt was changed at 82k - next change at 118k. However if the variator needs changing now then that's gonna cost at least £500.
Rear suspension bushes are always worth a look - does the rear end "clunk" - is there a bit of wear on the inside of the rear tyres? If the answer to both is "No" then great. If not - another £500.
Aircon - if all of the controls work - fan, vents, hot air, then the news is good and bad. Good because it is just an aircon problem - bad because that could be expensive - best case scenario - £100 or so for a recharge.
Headlights - not a problem - I have never met anybody who has ever used the electronic beam adjustment other than just to aim at a wall, turn the knob and say "oh so that's what it does". Just manually adjust them and forget.
Discussion Starter · #8 ·
So, after gathering some new parts - variator, balance belt, tensioner + some Powerflex bushes - it turns out the owner has lost the V5. Purchase cancelled!
No Alfa but hey, I've got some nice shiny parts :)
Can you wait for him to get one through from the DVLA???
Discussion Starter · #11 ·
Lost V5 means nothing,Get a bill of sale and check for outstanding finance,that should be enough to sort the sale
D
Appreciate that, just not in a position to wait 6 weeks to get the V5 in my name. The plan was to MOT and sell it asap (see below).
I could have done but something better has landed in my lap -
1 owner, 70k TS W reg, £1000 spent in Feb 08 - £2300. And it's two doors away:)
Just need to raise a grand in the next 10 days. I sense an ebay frenzy coming on..
I'll keep y'all posted;)
1 - 11 of 11 Posts
