1 - 14 of 14 Posts
Hi all
I'm starting to get a bit of judder in the drivers side wiper blade..everything runs smoothly and it does clear the whole screen (not like some of the problems that need the arm bending)
Is it just a case of new wipers?? If so, any recommendations...
Steve
got the same problem too, sometimes it works fine but start juddering. also found out halfords don't stock these wipers
ebay has cheap bosch wipers or www.wipers.co.uk also do blades with quick delivery.
If the blade is clearing the screen then you could try giving the blade a good rub down / clean to see if this helps the judder.
Clean the screen with a proper glass cleaner like Windolene or even vinegar - try new wiper blades - but also make sure there is no play in the bearing of the wiper shaft. Mine wore away in less than 18 months and had to have the whole assembly replaced under warranty. Its not a very sturdy design
+1. It will be diesel deposits on the screen. Get a good window 'polish' and thoroughly apply it. Usually it's a cream that you apply with a damp cloth with plenty of overlapping circular motions. When it's dry the surface can be cleared with a soft cloth that removes the resultant powder.
I take it, it's to remind us this still is an Italian car so expect problems :p.
Somtimes it surprises me that little things like these, you'd never find on another car but then again no other car is better looking that a 159
Just replaced mine with good old Tesco's 18 and 22" wipers. Noise gone. Tried the Vinegar, no good, just smelt like a fish and chip shop. Tried Rain-x, no good. Tried screen polish - no good. Windscreen is bloody clean now though!
I have found that 99% of the time its the wipers.
new wipers did the trick too. Bosch blades :thumbs:
now i just spray at any given chance just to see a clean piece of windscreen and no juddering. someone told me fiat say its an alfa/fiat characteristic, thought they would use any excuse...
1 - 14 of 14 Posts
