1 - 2 of 2 Posts
As per title, I got a new coolant temp sensor. It is a FAE 33723 in a Cambiare box VE375006. I spent a bit of time ensuring it was nothing I had done but it kept triggering a management code described as "coolant temp sensor circuit A". I put the original one back in and all is well from the management side.
I only changed it due to an under-reading coolant temp gauge (showing 70 degrees at a management displayed 86 degrees). Funnily enough, the new sensor was similarly far out; gauge reading 115 degrees when cooling fan kicked in around 99 degrees.
Time for a genuine one, I think.
Discussion Starter #2
Unfortunately Alfa Workshop has no stock right now. EPS is 1830286 & Facet is 73286 if Alfa Workshop doesn't get more soon.
1 - 2 of 2 Posts
