Hi all, how would i be to convert a jts to a jtd, i know engine and box and drive shafts exhaust, would swap easy, but would all wiring from behind dash need changing, or just the engine loom, will it be as simply as plugong into the loom from the car to the engine. I know the ecu is located inside the car on jtd, so it would need the dash removing. Is to much hassle?????
I would say that it would be too much hassle, unless you already own a JTS, a JTD, all the tools you need & all the time in the world.
Basically you strip the JTS down to a bare shell, strip the JTD down to a bare shell, and then reinstall all the parts from the JTD into the shell of the JTS. There will be some bits that are the same, but most of the important stuff is totally different.
