Can be the bushes on the clutch actuator fork which can contribute to this. Plenty of threads on here. Solutions involve replacing the top bush and trying to lubricate the lower bush by dribbling a small quantity of oil down the clutch actuator fork. I have had success by dribbling a small amount of plusgas down the actuator fork. Did not expect this to work as I expected the heat to cause the plusgas to dry quickly but has worked ok for me. I took the chance as I was expecting to have to change the clutch in the next 12 mths so had nothing to lose -I would change both bushes when this time arrived. As it happened I still have not changed the clutch and all still ok.Guys its normal if my GTD clutch pedal is stiff? but not all the time,what could cause this issue?
thanks mateCan be the bushes on the clutch actuator fork which can contribute to this. Plenty of threads on here. Solutions involve replacing the top bush and trying to lubricate the lower bush by dribbling a small quantity of oil down the clutch actuator fork. I have had success by dribbling a small amount of plusgas down the actuator fork. Did not expect this to work as I expected the heat to cause the plusgas to dry quickly but has worked ok for me. I took the chance as I was expecting to have to change the clutch in the next 12 mths so had nothing to lose -I would change both bushes when this time arrived. As it happened I still have not changed the clutch and all still ok.
Of course the clutch tends to get heavy when it wears so it could be wear and only a new clutch will sort it.
Tend to agree with you here. Would suggest that the problem is likely to be actuator fork bushes or one of the other likely suspects. It has been reported on here though that wear can give rise to heavy clutch and I'm assuming that this is due to wear on the pressure plate/release bearing. Have not experienced it personally so only going by others experience here. It's an issue that does seem to affect a fair proportion of modern Alfas so there must be some identifiable reasn for it.Not convinced clutches get that heavy with age because numerous people who had new clutches fitted under warranty, replaced due to heavy/stiff uneven pedal feel, found that the new light clutch quickly became stiff again within a few months. Alfa just changed the clutch but didn't sort out the release arm bushes.
