1 - 20 of 28 Posts
Let us find the speed at 3000rpm in all gears on both 1.9 5/6 speed and 2.4 5/6 speed JTD Cars.
Remember to write your car model and engine model.
Use this link to converte from km/h to mph :
Replace "100" with your own speed and press enter
Use this link to converte from mph to km/h :
Replace "62" with your own speed and press enter
Be aware speedo reading is not as precise as GPS readings
outcome can enduring with 5% or more, again depending on tire choice
Write it this way (Just for show) :
Alfa 147 1.9 8v 120hp - 5 speed
Speed at 3000 rpm. (speedo / gps)
1. - 20km/h
2. - 40km/h
3. - 60km/h
4. - 80km/h
5. - 100km/h
After this, we must find out which cars can use one of the other gearboxes.
Lets begin:
@ tomfromtelford
147 1.9 jtdm 16v -225/40/18
@3000rpm (speedo !)
1 - 32.19km/h - 20mph
2 - 48.28km/h - 30mph
3 - 80.47km/h - 50mph
4 - 104.61km/h - 65mph
5 - 140.01km/h - 87 mph
6 - 177.02km/h - 110mph
@ TribesMan
Calculated from gear ratios
147/156/GT 1.9 JTD 16V 6 speed - 17" 215/45 wheels
@3000:
1. - 26,2km/h
2. - 44,6km/h
3. - 73,3km/h
4. - 102,7km/h
5. - 130,7km/h
6. - 163,5km/h
147/156 1.9 JTD 8V 5 speed
@3000:
1. - 27,8km/h
2. - 47,2km/h
3. - 77,6km/h
4. - 108,7km/h
5. - 138,3km/h
@ TribesMan
159 1.9 JTD 6 speed:
1. - 26,6km/h
2. - 47,1km/h
3. - 78,1km/h
4. - 106,1km/h
5. - 136,7km/h
6. - 165,7km/h
159/Brera/Spider 2.4 JTD 6 speed:
1. - 26,3km/h
2. - 51,3km/h
3. - 79,2km/h
4. - 109,6km/h
5. - 138,5km/h
6. - 167,9km/h
@ TribesMan
MiTo 1.6 JTD 6 speed - 215/45/17: (looks like it has the same gearbox as 159 1.9... at least same ratios, but different tyres)
1. - 25,4km/h
2. - 44,9km/h
3. - 74,4km/h
4. - 101,0km/h
5. - 130,2km/h
6. - 157,7km/h
Mito 1.3 JTD 6 speed - 215/45/17 (same box as above, but different final drive):
1. - 22,4km/h
2. - 39,7km/h
3. - 65,7km/h
4. - 89,3km/h
5. - 115,1km/h
6. - 139,4km/h
@ Cuore_Sportivo_155
156 2.4 JTD 10V 5 speed worn standard 205/55 R16
@3000rpm (gps)
1. - 30km/h
2. - 51km/h
3. - 82km/h
4. - 116km/h
5. - 148 km/h
@ TribesMan
156 2.4 JTD 10V 5 speed == 1.9 JTD 8V
1. - 27,8km/h
2. - 47,2km/h
3. - 77,6km/h
4. - 108,7km/h
5. - 138,3km/h
156 2.4 JTD 20V 6 speed (same gearbox (GM) as 159 2.4 20V, but different tyres 215/45/17):
1. - 25,4km/h
2. - 48,8km/h
3. - 75,4km/h
4. - 104,4km/h
5. - 131,9km/h
6. - 159,8km/h
@ TribesMan
166 2.4 10V & 20V 6 speed (same gearbox as 156 1.9 16V, different tyres) 225/45/17:
1. - 26,5km/h
2. - 45,1km/h
3. - 74,1km/h
4. - 103,7km/h
5. - 132,0km/h
6. - 165,1km/h
166 2.4 "eco" 10V (same as above, only longer final drive)
1. - 29,7km/h
2. - 50,4km/h
3. - 82,9km/h
4. - 116,1km/h
5. - 147,8km/h
6. - 184,8km/h
Calculated from gear ratios and on 17" 215/45 wheels...
147/156/GT 1.9 JTD 16V 6 speed @3000:
1. - 26,2km/h
2. - 44,6km/h
3. - 73,3km/h
4. - 102,7km/h
5. - 130,7km/h
6. - 163,5km/h
147/156 1.9 JTD 8V 5 speed @3000:
1. - 27,8km/h
2. - 47,2km/h
3. - 77,6km/h
4. - 108,7km/h
5. - 138,3km/h
I dont know the gear ratios for 2.4 engines... so I cant help you there...
Discussion Starter #3 (Edited)
1. - 26,2km/h
2. - 44,6km/h
3. - 73,3km/h
4. - 102,7km/h
5. - 130,7km/h
6. - 163,5km/h
1. - 27,8km/h
2. - 47,2km/h
3. - 77,6km/h
4. - 108,7km/h
5. - 138,3km/h
Thank you, I updated my first post.
How about 159 ? does it use another box ?
Yes 159 uses another box... 225/500/17:
1. - 26,6km/h
2. - 47,1km/h
3. - 78,1km/h
4. - 106,1km/h
5. - 136,7km/h
6. - 165,7km/h
1. - 26,3km/h
2. - 51,3km/h
3. - 79,2km/h
4. - 109,6km/h
5. - 138,5km/h
6. - 167,9km/h
MiTo 1.6 JTD 6 speed 215/45/17: (looks like it has the same gearbox as 159 1.9... at least same ratios, but different tyres)
1. - 25,4km/h
2. - 44,9km/h
3. - 74,4km/h
4. - 101,0km/h
5. - 130,2km/h
6. - 157,7km/h
Mito 1.3 JTD 6 speed 215/45/17 (same box as above, but different final drive):
1. - 22,4km/h
2. - 39,7km/h
3. - 65,7km/h
4. - 89,3km/h
5. - 115,1km/h
6. - 139,4km/h
1. - 27,8km/h
2. - 47,2km/h
3. - 77,6km/h
4. - 108,7km/h
5. - 138,3km/h
1. - 25,4km/h
2. - 48,8km/h
3. - 75,4km/h
4. - 104,4km/h
5. - 131,9km/h
6. - 159,8km/h
1. - 26,5km/h
2. - 45,1km/h
3. - 74,1km/h
4. - 103,7km/h
5. - 132,0km/h
6. - 165,1km/h
1. - 29,7km/h
2. - 50,4km/h
3. - 82,9km/h
4. - 116,1km/h
5. - 147,8km/h
6. - 184,8km/h
I think thats about it... there is no info about Q-tronic gearbox ratios online...
Well the only gear ratios I could find for 156 2.4 JTD 10V were exactly the same as the ones on 1.9 JTD 8V engines... Maybe I got the wrong data. Can anyone provide gear ratios for 2.4 JTD 10V?
But I guess you might be right CS155, because with the torque the 2.4 can provide it would be quite stupid to use the same gear ratios as on 1.9 JTD...
This what I get with 225/40/18 @3000rpm
147 1.9 jtdm 16v
1 - 20mph
2 - 30mph
3 - 50mph
4 - 65mph
5 - 87 mph
6 - 110mph
6 can do 130 @ 3800ish rpm
Bump
Thanks.
Yours number differs from TribesMan's calculation.
But you also run tires with 2.98 percent smaller rolling circumference than those who TribesMan calculated from.
But it makes only a tiny difference !
@ TribesMan
Sure your math i right?
Speedo, I also have a tunning box.
So if you compare that to my calculations I guess it is quite right, because speedo lies at least 5%... and your tyres are a bit bigger...
Can you please test 4rd gear ?
Then i'll update the chart with your numbers.
4rth gear 116 km/hr...
and on a related note: never found my speedo to be off more than 3 km/h (at least not under 200 km/h), unlike the one in my 155 and 145... the 155 UNDER read when speeds got over 150, the 145 over reads by about 8-10 km/h...
1 - 20 of 28 Posts
