Hi I have a 2.4 JTD 2001/2 and the aux belt shredded it's self and then threw the cam belt out. I was wondering if the cams have followers which fail thus saving the valves.
sounds like you have bought a very poorly Alfa :hurt:
Repairing an Alfa Romeo JTDm with broken cam or timing belt
Also for the central locking on the other thread , It not something one would do much so i dont think anyone would know the answer so your best bet is to google and down load eLearn which is the alfa work shop manual
Hope that helps
lol we posted the same time
  • Like
Reactions: meterman
Hope that helps
Cheers http://www.alfaowner.com/Forum/members/mirlock.html I bought a scrapper today to fix the other 1 but the scrapper is to good. I'll try and fix the 51 plate and sell the 2000 when I got the other sorted. Well that's what I told the Wife.
Good luck with it all , im sure any problems you find someone can help or can point you in the right direction.
At least you started correctly "Never tell the wife anything if you do just lie" :biglaugh::jester:
2001/2002 is going to be a 10v engine, so no sacrificial rockers unfortunately. The cams are directly above the valves and its likely to have bent a few, the cylinder head is one-piece as well so will have to come off.
Its still not the world's worst job, just a bit more expensive than changing a few rockers.
How can an aux belt fail take out the cam belt? Is their not a belt guard seperating the 2?
