1 - 11 of 11 Posts
Ok cars been pointed downhill on drive. Footwell keeps filling with water.
Gah nothing on kick plates
Guessing it's a shite weld on a body panel...any other suggestions?
Blocked drains from the bottom of the screen? I think the ventilation system gets it's air from there, so conceivably if the plastic panel where the wipers are (can't remember it's proper name!) can't drain, it could dump through into the car?
Just a guess, mind...
it's a possibility...i'll fill it with water tomorrow morning and see if it goes down, or goes into the holes!
I had that on my old VX Signum - blocked drain in the front scuttle then water would build up like a swimming pool and overflow through the aircon/heater vent. Do you park uner trees?
nope...no trees anywhere either here or at work..it spends the odd evening under trees at mums, but not significant no.
Hi Ray, i'm not that suspicious of the door to be honest...the kick plate isn't wet...
I will admit, that the bottom of the weather seal (where the two ends join), after it's raining..shows signs of wetness..BUT the carpet on the inner sill, that leads up to the door, is bone dry...and i could hear a 'drip drip drip' with my head in the front passenger well earlier this evening..
Got your note - other than getting yourself a look on Eper and Elearn, I cant suggest anthing, Ive never dismantled this area.
Mr Mike and Chris
You win THE PRIZE!!!
Blocked drain on drivers side...blown it out with an airline...now whats the most effective way of getting the frigging thing dry urgently?
Mr Mike and Chris
Ironically it's probably using the air-con :lol:
Obviously mop up and remove what you can first.
1 - 11 of 11 Posts
