1 - 20 of 29 Posts
S
Yesterday, was happily tanking down the A1. and a horrid rubbing grinding noise appeared, pulled off at it turns out the a plastic lump of undertray that seems to cover fuel lines and filter on the back right hand side of the car has partially come away. The bolt seems to have run for cover. Its the back edge, so question time. As I don't have a stock of random sized bolts and will have to go buy one, does anyone know what size of bolt I need to re-attatch the plasic undertray wotsit to the car?
Cheers all.
Andy
M
Discussion Starter #2
I'm pretty sure it is the same bolt that holds the rear undertray in place (around the edge of bumper). Maybe take one of these bolts out and try it, then you'll know for sure.
Marlon
S
Was hoping not to remove any other bolts!
I don't really want to do any harm with ham fisted fiddling.
Do those CDs that some bods own not tell you what size the bolts should be?
If so, and anyone is near one, any assistance would be lovingly accepted, as the bit is currently held on by string!
W
The rear drivers side is a plug, part number 60625251, £1.70.
wrinx
W
Next plan could be large penny washer and self tapper...mine was done like that by a garage!!!
wrinx
Andy i`m not sure but i think the bolts are m6x1.25mm or are they m8x1.25mm now you got me thinking :confused:
Would have a look but mine aint got a rear undertray :rolleyes: was missing when i got the car
S
The botch it and pray approach seems to be the way forward. I feel a slef tapping screw or two in the pipeline. Am I likely to go through anything under there?
W
Speedy, V6's dont have undertrays (not at the front anyway) :p
wrinx
W
Andy, I would go and buy the proper bit to be honest but if you must drill and screw it the put the hole near the edge of where the plug should be. You should be able to stick your finger in and feel around the recess (fnaar fnaar!)
wrinx
wrinx:
wrinx
You sure really really really sure
Only asking cos mine has a front undertray and some remnants of a rear one thats been lost in the past :confused: :confused:
W
speed freak:
wrinx:
wrinx
Positive...dunno how you've got a front tray??? They only have the rears fitted. Think its the same for the 8v's too......cant remember :confused:
wrinx
Its definately there all be it hanging on by the skin of its teeth now but it`s there and it looks like it has the original mountings and not a botch job
Must be a one off :confused:
M
Discussion Starter #15
The front undertrays can be fitted to original mountings I believe.
Hmmmmm...... got me thinking, maybe I should get a front undetray........
Marlon
J
Discussion Starter #16
How much for the front and rear under-trays?
I thought about making one up out of 1mm aluminium sheet but decided it would be too much agro!
FGN
wrinx:
Front £91.47 but cant find the rear on the CD :confused:
wrinx
SH$T Was thinking about replacing mine when it drops off but think at that price i`ll keep cable tying it back on :rolleyes:
W
Discussion Starter #19
marlon:
Marlon
Wouldnt bother Marlon, they muffle a lot of that lovely engine sound. Nadine ripped the Twinny's of when she went ice skating and it sounds gorgeous now :D
wrinx
1 - 20 of 29 Posts
