1 - 1 of 1 Posts
It is that time of the year again
ARNOLD CHATZ & ARCOP TRACK DAY
IMPORTANT POINTS TO NOTE
The trackday to be held at Zwartkops promises to be great fun! The following points will assist to make the day run smoothly and avoid frustration. WHAT TO BRING? You will need a crash helmet, long sleeve shirt, long pants and closed, non-slip shoes. Bring along some cash for regalia and something to eat at the canteen.
WHAT ABOUT MY CAR? You car will be scrutineered before you will be allowed on track. The following have to comply, in order for your car to be allowed on track:
• Your car must be road worthy, therefore it has to have a legal seat belt, road tires in good condition, windscreen without chips or cracks and no fluid leaks.
• Your car battery has to be securely fastened.
• Your fuel tank has to be securely fastened.
• No loose body parts to be on the car.
• Brakes have to be in good condition and the brake pedal should be firm.
• Exhaust should not leak. In order to enjoy your drive on the track even more, check the following before you go on track:
• Tire pressure should ideally be slightly higher than standard. This will help prevent tire deformation during cornering. For tires with standard pressure of 2.2 bar, increasing the pressure to 2.5 Bar should suffice. Do NOT over-inflate tires, as they may burst on track.
• Check water, oil and brake fluid levels and ensure all levels are topped up to the MAX mark.
• Ensure that there are NO loose items in the car or boot. Loose items shift and may cause damage.
• A good set of spark plugs can make a difference in performance. COSTS paid at the track:
• Drivers (Car club members) = R 400
• Drivers (non-car club members) = R 400
• Passengers = R 100pp Registration on the day is open between 09H00 and 11H00. NB: All drivers and passengers MUST complete the indemnity form.
1 - 1 of 1 Posts
