Hi Guys
Keep noticing every now and then that the idle on the GTA goes all weird on me, then it sorts itself out?
I drove home after work yesterday pulled up outside the house and started to reverse, i noticed that the car was idling very low and kept wanting to cut out the alternator light flashed on and then the revs built up and then cut etc etc
Then noticed that if you rev the car and hold it at a set number of revs it sounds like it is missing as you get a small pop through the exhaust, quite noticeable with the scorpion box fitted
If i left for about 1min it picked itself up to correct idle round 800rpm but if you reved it and let the throttle go it would try and idle again really low
I think when i looked the car was trying to idle at say 200rpm hmmm not good
Can anyone think to what it may be?
I did plug in my little OBD 2 reader to check for missfires or coilpack fault but no faults came up???????
dont want to be sitting at the lights and it cuts out on me
