1 - 20 of 21 Posts
Anyone else have problem that Recent calls and Contacts are empty after iPhone update on iOS 13? Using voice control, i can still call anyone in Phone contacts. Havent updated to the latest 13.1.2 though.
Recent calls list get new entries after calls are finished but next time car is used, the list is empty again.
I have old infotainment hardware (2017).
My,contacts aren’t showing on infotainment screen since I did the update!
After update to iOS 13 I lost contacts from the infotainment system.
To recover, I had to delete the phone from the list of bluetooth devices on the car and delete Alfa Connect from the phone and re-pair.
Sorted OK though I have lost pairing at least once since. Perhaps that was due to the update to 13.1.1. I've not tried 13.1.2 yet.
Andy
Andy
This. I've got 13.1.1 & it seems ok so, hopefully, it was the jump to 13 that caused the issue.
I can confirm that re-adding iPhone to the devices list fixes the issue with empty contacts list etc..
I do have contacts by my favorites have stopped working which is really annoying. Anyone on IOS13 who still has their favorites?
Btw, removing and adding the phone, doesn't seem to help with this.
I have same problem with my Stelvio. When you remove the phone you remove the favourites so you have to add them back in. Not been having any problems since I did the next update IOS 13.1.2.
I’ve not had any issues UNTIL updating to 13.1.2. Have tried deleting phone and re-adding, with mixed results depending on whether I select ‘all contacts’ or ‘OWA’ (whatever that means)... either pulls through full phone book or just favourites (from my phone), however...
Had all contacts stored this morning after pratting about, but favourites was just showing ‘searching’, with no option to add. When I came back to the car this evening, back to square one (i.e. nothing).
Frustrated - not Alfa’s fault Apple have decided to change something... has worked perfectly for last 2 years
I did have problems with the first iOS 13 release, but not with 13.1.2. I've got the early Infotainment system hardware with the latest software for it and an iPhone 7.
I'm updating the phone to 13.1.3 at the moment. Fingers crossed.
Andy
PS having just updated to 13.1.3, I find WiFi Calling is no longer available. Not an Alfa issue I know.
PPS WiFi Calling working again. Probably a Three issue
Right then... no improvement for me - seems to be ok when I first set it up (well, I have contacts but no favourites), but on restart I have nothing.
Rubbish. Anyone had any luck? I’ll check s/w version on car and report back..,
Yes having the same problem with just the favourites not showing did a reset network on the I phone that got me contacts back tried deleting favourites and re adding no joy 😒
Hi all. Did anyone get a solution on this? I’ve had issues since updating to iOS 13 early oct (currently running .43 software- 17 reg Giulia...Had it booked in to dealership and raised with Alfa with no luck....sort of hoping it’s just a update on the car software will sort...
Has updating the software helped anyone else???
Haven't had any issues with mine running 13.1.3 & last edition of 002, but then again I don't use favourites -recent calls is what I use (small group of friends ??)
This is quite frustrating. Updated XR to 13.2.2 and have now the contacts but remain without favorites.
Anything else we can do?
Interesting that there's a banner on the TomTom site about IOS 13 and Bluetooth connections. Seems to be an issue with the operating system.
My contacts have been lost on my 67 plate Stelvio infotainment system ever since I updated my iPhone to iOS13. It worked perfectly before this. I have now tried iOS 13.2.3, the contacts appeared once then subsequently never again. Any thoughts?
I lost my contacts when I first updated to iOS13.1. To recover them, I had to delete the bluetooth connection both from phone and from the infotainment system and re-pair. Subsequent updates of the phone, now on 13.2.3, didn't cause problems.
My car is a Q1/17 Giulia with the original infotainment system hardware version and the latest software that will run on that hardware.
Andy
1 - 20 of 21 Posts
