Hi guys,
Been a while since I have found a fault haha..
Basically on my car where the heater/airconditioning nobs etc are found everything from the number 2 (which is the heater setting) left is a good brightness.
However everything right of the number 2 seems to have much duller illumination to the point you cant really see it in the dark.
Sorry this isn't easy to explain but am I looking at a fault or poor design?
Administrator
Il try to but if someone could just look at there's it would probably answer it. Also its probs obvious but this is with the lights on.
R
Think mines is a different dash to yours but all the dials and knobs are well lit, so sounds like a fault.
It seems to have started working as normal again now. And it does bother me its brand new and should be working correctly.
Hi just seen mine my rear view heater for the glass is not lot All and the heater hot or cold thing is very dim have you solved your problem ??
