hi guys,
I have a strange problem on my GTV. The internal fan runs constantly at the first speed, whether the ignition is turned on or not. I removed all the fuses and relays in the internal fusebox trying to find the problem and it continues running with no fuses in place. The only way to stop it is by removing the 30amp fuse in the engine fuse box (the one to the right of the engine, above the ABS unit). This leads me to think that this fan may somehow be connected directly to the battery and possibly have a relay which may be defective. The other strange thing is that when the car is running, the fan switch has no effect on any of its speeds, as though it no longer works.
Does anybody have any understanding of how this system works. I would appreciate any input.
Kind regards
Sean
Kind regards
Sean
