Removed the door card to look at why the door handle is loose and found the spring in two parts.
I have done a search and found the part number for the spring.
Is there any guide on how to replace the spring it self?
Any help gratefully received.
Frank
1. remove door card and remove these screws http://www.shrani.si/f/D/d0/1VXOdo9U/fotografija0907.jpg
2. Remove the safety pin, pul out the cilinder and the spring will fall out http://www.shrani.si/f/46/SA/KtoCMAG/fotografija0908.jpg
3. Reasemble by putting in the spring first (place it right), then the cilinder and the safety pin http://www.shrani.si/f/3U/C4/2lw726SQ/fotografija0909.jpg
4. Place the bowden cable into the correct position, otherwise your central locking won't function properly: http://www.shrani.si/f/24/7t/FQP4rrA/handlegood-small.jpg
If any problems occur, search for bouncing locks - you'll find everything there. Good luck!
When removing door card be particularly careful of connection to basal courtesy light. These snap easily at the best of times and are more prone in the colder weather
