Hi everybody!
I've got an '06 147 JTD - second I've had, and the 6th Alfa! Yes, I've got it bad! :)
Now, I don't know how the rain works in Italy, but the intermittent wipe speeds are pants! I can't say it's only on the Alfas as I've known other makes to be as bad:
The fastest 2 settings are pointless - you may as well have the wipers on normal speed, and the slowest is still not nearly slow enough, squeaking its way across the screen with anything but a serious amount of drizzle.
Does anyone know of a way to alter the timing? Is it ECU based and alterable via software or would I have to rip the relay apart?
Many thanks.
Hi Dave,
No, you misunderstand. I'm not reporting a fault; merely stating how the car comes from the factory.
The delays between wipes are too short and I want to know if they can be altered, either by reprogramming the ECU or physically changing parts elsewhere, say in the control relay.
Cheers,
Mike.
