My heater doesn't blow any hot air, no matter what temperature I set the controls to.
I replaced the original control unit, with a second hand one, earlier this year and the aircon works fine when set to cold.
The rear screen heater isn't working either (not sure if there's a link).
Any ideas/help would be very appreciated because it's freezing driving to work!
Daft Question but you have got water/antifreeze in your expansion tank haven't you ?
Had the same in a Mondeo, turned out to be a water leak, 1st symptom was heater packed in.
I'd suspect your thermostat or water pump is on it's way out, check the top hose whilst the car is warming up, if it stays cold then your stat is probably shot.
M
Do you not mean if top hose gets warm with car and doesn't stay cold till 90 stat is probs shot?
