Almost like eper. Good for checking OEM parts out: https://www.fiatdalys.lt/en/catalog/groups/W0/0/0/M9/0/GD
Those are the recommended retail prices from Alfa Romeo.I saw that. Looks good but very pricey!
What percentage premix are you running? I find it unusual that a water bottle for your windscreen washer can't hold meth when most good windscreen washers contain up to 35% meth?all i want is a water bottle for my punto
and the specific heat capacity of water is much higher than meth so it cools the charge much better for the same volume injectedThat won't change much though. Pure water injection can raise the octane value of fuel with no methanol content by as much as 15 points from 95 RON to110 RON. Pure meth only has an RON of 112-115 octane. So pure meth mixed with pump fuel results in a RON of somewhere in the region of 99 to 102 octane.
Meth needs to vapourise to cool the intake charge. In doing so, the meth displaces oxygen. By running 65% meth/water you won't gain much but suffer consequential damage like the damage to your tank and seals. 35% is the ideal ratio.
To get a 35% mix, you add 1L water to 1L meth. You will end up with a cool 35% meth solution.
You need to decide what you want to do? Cool the intake charge? Improve the octane rating? Both? For both, you need water/meth. With more water than meth... #ShuttupAndTrustMe...
That is too much meth. I am going to post something that you will need to read and read again, because it is important:calc is at 2 to one at the moment. 2l meth to 1 l water
You can do that but that begs the question: Why? To cool the inlet charge? NOS is way better than Meth at doing this. So what you will be doing in this case is diluting the NOS with meth for no reason.How about running NOS with Meth? So oxygen problem solved :thumbup:
Just messing about... My next suggestion was to use nitroglycerin... In medical use it helps flow of oxygen and blood to the heartYou can do that but that begs the question: Why? To cool the inlet charge? NOS is way better than Meth at doing this. So what you will be doing in this case is diluting the NOS with meth for no reason.
