High All......Has Anybody out there used Injector Cleaners / Treatments and are they any good / any use. Also can they cause any unwanted side effects like killing the Cat or blocking fuel filters ????. I have a 156 2.0 JTS, now at 105k miles and has been fine to date but a few weeks ago it started to misfire very slightly under load....Doesn't do it on every trip and never when cruising on a light or steady throttle.....Also appears to be in the 2500 to 3500 rpm range, but as I say only when pulling medium to hard in a high gear through that rev range.... The plugs and coil packs have been checked and these are not the culprit.....My Indie suspects it may be an injector but until an engine warning light pops up with a fault code we have little to go on......In the meantime I thought a dose of injector treatment may be worth a try.......Any comments would be appreciated and which is the best one to go for....Many thanks in advance
