Hi guys,
i searched a lot the last weeks for better injectors for my car. I want to share all these duration maps with you. I think that the best way, to share the informations in one topic. If you found other/better injector, please write in this topic and i update the first post.
I've also created an excel file with the most duration tables and extrapolation options for more iq and pressure. You can change the red values in the sheet.
Here is a list of injectors that fit into our engines:
0 445 110 111 - CF3 injector (55190808 or 55192489 or 55192534 or 73503097)
0 445 110 159 - CF?/GM injector (55191958 or 55192739 or 93184794 or 5821100 or 93179047)
0 445 110 213 - CF4 injector (55192740 or 55198219 or 55217235 or 55221021)
0 445 110 243 - CF4 injector (55196295 or 55198218 or 55221020)
0 445 110 299 - CF5 injector (55202251 or 55209382 or 55221024)
0 445 110 308 - CF4 injector (55208183 or 55221022)
0 445 110 327 - GM injector (0821438 or 55496735 or 55566050)
0 445 110 341 - CF4 injector (55218067 or 55218785 or 55221019)
0 445 110 419 - CF6 injector (55233955)
0 445 110 423 - GM injector (55577668)
0 445 110 682 - CF? injector (55263233)
Here a 40mm³ comparing and at the end an 100mm³ comparing
And here the duration tables
Excellent bit of info there, no doubt people will find this very useful.
Indeed it is.
I was driving a while with 213 injectors and stock 243 map-although the injectors are very similar from the day we changed duration map-different car-on better way:)
