My info center button on the stalk stopped working, everything else seems fine, nothing listed for a fuse. Any thoughts ? Cheers.
Take the cowl off the bottom of the steering column and check the connector. I think its a white 2 pin as I remember :)
:think: the button on the end is controlled separately by two wires while the indicator is part of a boxed unit that fits round the column. I would say that the reason it works is as the stalk is push down it's moving the broken wires back together. You might not even be able to see the break as it will be cover by the wire sheathe. You could test the continuity of the two wires while the stalk is in the thre positions using a multimeter.
