So today without warning the indicators started to "go slow" that is work at half speed on both sides and then nothing. I've already checked to see if the heater matrix is leaking and that's not the culprit, the ecu's and relays have been bagged as best they can in such a confined space. Being a later 1st version 166 I only have a large blue relay and a smaller green one lurking underneath the central console. As I was at work when this happened in Southampton I rang the Alfa Shed in Fareham who advised that a relay switch is in the steering column and they go regularly. So I will be checking this out as I wanted to remove the plastic cover behind the steering wheel (not playing with the airbag before anyone asks) to see if this is true and to see if the left indicator (when working) can cancel.
Can I find the right sized allen key for 2 of the bolts that hold it all together, one for the morning.
My question is am I on a wild goose chase by doing this and should I be looking elsewhere?
