Guys
Was wondering if ou could help me. When i turn the alarm on the indicator lights flash but the right drivers light stays on. If i turn the alarm on and off long enough it seems to cure it untill then next time i turn the alram on or off.
Any help would be appreciated
*all* the indicators on the drivers side stay on? Can you replicate the problem by turning the hazards on?
Hi
Yeah all the indicator lights stay permanently on . If I turn the alarm of and on enough times they go out but will come back on and stay on the next time I lock the car.
'98 GTV V6
If you have a Meta alarm system, then I think is down to a faulty relay within the alarm ECU itself. Have a word with the guys at Abacus Car Alarms.
Same issue
did you ever solve this? I have the same problem
happens occasionaly to me as well only it's the left hand indicator that stays on and the only way to clear is to disconnect battery for a few minutes, then reconnect. Only problem with this is you then have to reconfigure the radio every time:mad:!!
PKR your territory perhaps??:)
