my 3l v6 has developed a fault in the indicator, hazard light system. The relay is ok, the car was parked, when I returned to it there was a strong smell of burning plastic, the emergency warning switch button seems to have no resistance to being pushed in/out, before the fault appeared the emergency flasher button blinked when indicating to turn but only when 1 side was operated. Any ideas where to look for the fault? How do I change the emergency flasher switch?
Administrator
GT 2.0 JTS
Remove the ics, the flasher, front and rear fog light switches are in a separate module which can be removed from the rear of the ics.
also you might want to check the m45 control unit to see if it is ok.
