Hi there,
I have a 2006 Brera and today the I got an orange 'bulb' failure' light on the information panel, accompanied by fast clicking sound when indicating. Also had a 'replace front left bulb' message popping up.
Trouble is, that ALL indicators (and the other bulbs) are working perfectly.
Is there a known issue with these and if so can you help me to rectify it?
Thanks, Eamonn.
Have a check of the connections for signs of corrosion if all good change the bulb anyway and see if it clears the fault
Thanks Johnny!
I removed the connectors and all in good condition.
However, I was in the process of taking out the bulb earlier but it seems soooo awkward that I stopped trying. It seems impossible to get my hand right into the back of the bulb never mind removing the out of sight clip! Better have another go.:disappointed:
Indicators just pop out after half a turn. If they're working I bet there's some corrosion on the connector. Put new bulbs in anyway, see if that helps solve it.
