Driving along today and went to indicate right and i could hear the 'tick tocking' but the green arrow was not flashing on the dash.... when i got home i was trying it again and it seems that when i am stopped it works!
Anyone got any ideas what this could be and how to fix it? its so annoying!
1.st you should check the rear bulbs if any of them are malfunction. If the indicatorbulb is somehow damaged this will show in the front indicator as well due to impedance fault. If all are ok, try to pull out the dash and replace the small bulb in there ... it's one screw in the top of the clock and you can pull it out gently, then remove the connector and you have it all in your hand. The bulbs are of the type T5 12V-1.2W ...
