1 - 10 of 10 Posts
P
Discussion Starter #2
205/50x15 is a good size for the 7" alloys and the Alfa 155.
Used to have this size on my 6.5" Alfa alloys on my previous 155.
Good handling, looks and comfort.
W
The 6.5 or 7 is the width of the wheel, don't worry too much about this. The narrowest tyre you want is a 195 but I think the 205 is better. You should also be able to get a 215 tyre on but may get some nasty chafing :O
wrinx
W
Re: Tyres
I had loads of Khumo's a few years back, dunno if they've improved but they're a hard tyre. Ok in the dry but a bit iffy in the wet.
wrinx
I'll second Wrinx on that.
Still a decent choice if you are on a budget, their new tyres are getting better all the while.
M
I have Kumhos on at the mo, not sure what model, will look later. They seem ok but nothing special, break traction too early for my liking, can;t seem to get any power down on a bend.
But the sliding is fun.:D
M
They are the wrong size for the 155 though.
Should be 205/50/15 or 195/55/15.
I just stuck a full set of 205/50 15`s on the wife`s Silverstone today seen as she was driving round on a flat tyre the other day :rolleyes: :rolleyes:
They were Maxi`s or sumat just a budget thing ...............got 4 for £119 inc vat ;) :D
W
Good point Marlon....only let down by the fact that the difference between 195/50 and 205/50 is -1.71% or -10mm :O and the difference between 205/50 and 195/55 is exactly the same error but positive +1.71% or +10mm....wierd huh!
So the choice is 205/50's or plus/minus 10mm :O:eek::eek:..there is no tyre size nearer for 15's.
wrinx
1 - 10 of 10 Posts
