I have a GTV with the code light continuously on - thus it won't start. What a great invention by Alfa this was. I would like to check the antenna around the steering wheel column as this seems a good starting point. I've unhooked battery and reconnected etc.
Quick question - from first looks it seems that you have to remove the steering wheel/airbag to then remove the column cover to get to the antenna - is this correct?
Cheers, David
Cheers, David
