Hi all, I've got a wee problem with the old girl (and I don't mean the wife). I have a 156 2.0 TS on a 2000 plate
Let me explain.. Every so often the car is cutting out and the "Injector Warning Light" is coming on. The car then wont start again, but if I leave it ten/fifteen minutes she will fire up again as if nothings happened. This is now becoming more and more frequent and it's really starting to annoy me. My nearest Alfa garage is a fair distance away and before I make the arduous trek up there I am wondering if this is something simple. I suspected that one of the injectors was getting blocked so I have put an injection cleaner in the petrol, but this doesn't seem to be working.
Has anyone experienced this? and what the probable cause is.
Korky
I'm sure people with far more expertise than me will put an answer in to this one but that sounds similar to the ECU problems i was having a couple of weeks ago, intermittent but getting more frequent.
could it be the cranck sensor, TDC Sensor (same thing) getting hot and failing sounds similer to other stories of woe on here run a search
hope it helps a little :)
