Has anyone ever replaced a set of ignition leads on a later model 97-on. I'm wanting to replace mine but can't seem to find out where they are connected (not the coil side) as they are wrapped in tape.
Any advice or past experience would be appreciated.
Thanks in advance :)
On a '97 on model, there aren't really any ignition leads - not of the HT type anyway. There are low voltage trigger wires probably the ones in the tape that you mentioned, which trigger the four individual coils (one for each cylinder) under the alu head cover. If my memory serves me correctly (I replaced the cover as soon as I looked under there - too complicated!) each coil sits on top of the rubber insulation and connection for the main plug for that cylinder, plus a short HT lead to the secondary plug for the next-but-one cylinder. So for the main plug there's no lead to break down, but the coil may fail, and if the secondary lead fails, (the 'twinspark' bit) it won't really make that much difference. If your coils are failing, prepare yourself for a bill a bit bigger than the £10 for a normal set of HT leads!
Thanks for that Richward, I suppose the leads that can be changed are from the coil to the secondary spark plug. Someone mentioned a while back that the leads could be sparking to the alloy cover which made the car feel irregular, these must be them.
Cheers :)
Hi
I've change 2 of the 4 leads between the coils. They cost about £16 each from the Alfa dealers. By the way one was a short one and one was long, but they were about the same price. By the way if my memory serves me correctly 2 of the coils are on the main plugs and 2 are on the secondary plugs . :p
