1 - 10 of 10 Posts
I don't think there's an easy answer to this one, but here goes anyway just in case anyone has any suggestions... :(
Red '98 Spider, while reinstalling centre console and wanting to test the lights, I pressed the button under the ignition key, and turned the key backwards to 'Park'. Side lights and heater control lights etc. came on, great.
Then I found the key would turn forward (to 'Stop'), lights went off, but the key won't turn any further!
Thinking the steering lock was engaged, I refitted the steering wheel (which happened to be off) and turned it. Then the steering lock really was engaged, and the key still wouldn't turn clockwise past Stop.
I tried fastening the steering wheel on properly (doing up the nut), in case the column has slipped inwards, but no change. I used the spare, unworn key for the car. That turns more easily to Park (with button pressed), and back to Stop, and it's easier to pull out and put in. But it won't turn past Stop.
I sprayed in lots of penetrating oil, which again made the key easier to turn between Stop and Park. I have tried turning the steering hard against the steering lock in both directions while wiggling and turning the key. Still the key won't turn past Stop.
I even tried the key from my other Spider. That won't turn to Park. It's easy with the right key, therefore, I think the lock tumblers must be working.
I feel that the steering lock has somehow jammed, even though the steering lock wasn't even on when the key first refused to turn.
Of course now I can't get the steering wheel off, so I can't get the column covers off - two of the screws are obscured by the steering wheel, which obviously can't turn. In the morning I will use an old pair of small pliers, some washers to span the handles, and a couple of long bolts in the specially-threaded holes, to draw the wheel off the column.
After that I guess I will remove the lock barrel and if that's no help, I'll have to drill/grind the steering lock off the column...
Grrrrrrr! :mad:
-Alex
I'm sure you've already checked, but is the little button under the lock stuck? I had a similar problem some time ago & the button wasn't releasing properly & that prevented the key moving normally.
Thanks - button seems to work but seems likely that would be the problem, since this all started after I pressed the button. Probably first time in many years because it's an NZ-new car and almost no-one parks with park lights on in NZ.
-Alex
Making some progress now - got the wheel and column covers off. Tried to remove steering column - got the bottom UJ off (slow and painful) but can't get the adjustable bolt/release handle out, even with fuse box out of the way. There just isn't space to get it out (the service manual suggests there is). Tried to drive out the round-ended pin (part of clamping mechanism), no good.
After all the whacking, the key turned to 'On' in a freak accident so the lock barrel can be removed. Problem appears to be slackness in the pawl that disengages the steering lock. If I could get the frustrating greasy alloy guts out, I could probably fix it, or remove the steering lock completely perhaps, provided that allows the key to turn (at the moment it doesn't).
Next move is probably still the same anyway - grind/drill out the shear-headed bolts. I tried using a punch to undo them (as shown in the manual) but that just chewed up the heads.
Why does everything have to be so difficult? Five hours spent on this and not fixed, just more of a mess than ever!
-Alex
That part of the steering column is only supported by that black bar with two nuts at the A pillar, a bolt at the tunnel and another bolt* that sandwiches the heater unit between the support bar and the crossmember. Why not undo those fastenings and take the whole lot out of the car?
Pic of the bar here :
http://i1134.photobucket.com/albums/m615/pkr1/Alfa Romeo GTV Phase 1 - Retro Fit Climate Control/3 Installing the climate control unit/3-2 Crossmember modifications/2011-11-16_14-10-45_DSC_0139.jpg
and with the gubbins removed -
http://i1134.photobucket.com/albums/m615/pkr1/Alfa Romeo GTV Phase 1 - Retro Fit Climate Control/3 Installing the climate control unit/3-2 Crossmember modifications/2011-11-13_16-25-42_DSC_0075.jpg
Caveat : There may be one additional bolt. There's a flat piece of steel going between the steering column structure and the crossmember behind the dashboard. I can't remember if it interferes with taking this bit out.
* Not sure how accessible this is with the dashboard in place though.
Sorry, a bit more complicated than that. There's a bolt that helps mount the dashboard in the main instrument cavity. It goes into the hole just to the left of the green connector in the first picture.
Same problem
How did you fix it?
I have eksakte problem!!
Alfa Romeo 916 GTV 1995 Can not turn the ignition switch forward?
That's classic broken ignition switch problem. I've had it happen twice on two different cars. You'll need a new ignition switch. I'd also suggest never using the 'Park' light position on the ignition switch. It's a known weak spot.
How do I get it out? The key must be turn in ignition position to pull it out and the key can not turn forward.
Is it enough to change the lock cylinder or should it all be changed.
That part I can't help with. I ended up taking it to a dealer to sort out. It's just the ignition switch itself that needs replacing. The lock cylinder etc all stays. The switch is just a rubbish bit of plastic....not very nice at all.
1 - 10 of 10 Posts
