My alfa 1.8 worked fin 'till yestarday.
I drained the battery (well the amplifier did but nevermind) and took the battery out (no problems there) and charged it.
I connected it back and it started just fine except RPM jump up down from 800-1100. Get jumpy while driving sometimes. If i push to 4000-5000rpm i falls bellow 1000 and goes back to normal.
HELPPPPPPPPPPPPPPPPPPPPPPPPPPP!
It's a 1.8 widebody
lp
of a coincidence!!! Sorry, cant help more :confused:
wrinx [/QB][/QUOTE]
I've changed the lambda sensor 10.000km ago! Argh!!! Can bad fuel be causing this?!?!?
(our fuel is really baaaaaaaaaaaaaaaaaad). Could the battery damage lambda sensor?
l8er
try cleaning out the idle control valve might be carbonned up gives that sort of symptoms :D
sounds to me like you have unpluged something by mistake..check all the sensors and leads around the battery area also look to see if you have pulled off any pipes by mistake.
