Hope anyone can help. At idle the RPM's fluctuate between 1000 and 950.
I understand this to be some type of vacum leak. If so where do you sugest i start looking for it and how?
thank you for any advise
Banned
not many places to look for that actually !
2 vacum hoses leave from each side from throttle bodies.
Then there's one that leaves from the fuel regulator but that one wont make any difference on your revs.
Thats about it !
If that doesnt work out, clean the sensor inside the airflow meter with a clean cloth and some brake cleaner and change your sparks :thumbs:
If none of the above does the trick, let it be. Just take it out for a spin and rev it hard ! could be some dirt in the fuel lines or injectors that will clear out
thank you supercharged.. could you pleas explain the exact location of the sensor inside the airflow meter.
Banned
well thats easy ! just take off the rubber hose that connects your flow meter to your air filter and have a look inside !
There is a litle "door" that can be pushed in and you can see the sensor hanging like a needle from the top :thumbs:
