1 - 12 of 12 Posts
Im thinking of buying a 156 not a bad price, but the owner says it wont idle and cuts out, and has been told this is the MAF or (ISCV whatever that is?), is this right, or could there be a more sinister problem? any feedback would be great
It could be any number off things m8... See if the car starts and runs with the Maf sensor disconnected... If it does then you pretty much know it is just that.... reserve £200.00 off the car's asking price to cover a new maf and any other sensors that may need changing.
It may be worth while cleaning the MAF and throttle body butterfly if you buy it before going replacing parts... Plenty of tutorials on how to, it's free to do and doesn't take long or complicated to do! Just do a search m8.
90% of the time, that is all they need... Don't take "replace the maf" as the only option.... It's so easy for anyone to suggest it but it isn't their money they are wasting, it's your's ;)
As with all MAF issues... there is always a cause to a problem... Check that the air filter box lid and relevent induction hoses are secure. Dirty, un-filtered air is the primary cause for MAF failure... Sort that little lot out and you should have very little hassle from it :thumbs:
Ive bought the car, no difference when the MAF is unplugged, so i assume (and hope)its the ISCV????
Its a 98 2.0, Sport pack, 101k full history mint condition £400, so I think ive had a good deal? Just hope the repair is simple
How much MOT and tax has it got? What are the tyres like? When was the cambelt last done? So far it doesn't sound like a bad deal at £400.
Tax and MOT till end of aug, cambelt done recently, serviced 2k ago, all newish dunlop (6-7mm), wonder what this idle thing is going to be though
Good deal m8 :thumbs:
1.Clean the throttle body butterfly m8 (carb cleaner and then wd40... wipe down thorougly).... If they get dirty, they tend not to shut properly causing idle issues.
2.Make sure that all the pipework from the airbox to the throttlebody itself is secure.
3.Check the rubber hose from the MAF to the throttle body for any splits.
4. Perform an ECU reset proceedure (do a search on how to do it)
5. Take it out for a bloody good thrashing and more importantly.... Enjoy!
6. If it still doesn't run right... Get the fault codes checked & cleared ;)
Banned
Did you get it from a guy in Bristol?
If you like pop over and I'll take a look at it for you.
Ill have ago at those checks tomorrow and see what happens. No coleford, no too far from bristol, this was the item number on ebay 130306896142.
Thanks for the help too!
Ive cleaned out the butterfly valve, was really clean, so I assume its already been done by previous owner and also the isle speed control unit thing, looks new. So ive called an out electrician out to run diagnostics on it, if that dont work its dealers here I come £££££
It could be the lamdba sensor (only one you'll be please to hear on a '98 - pre-cat) or the idle actuator isn't setup correctly.
Try the throttle reset first: turn igntion on for 90 secs, then off for another 90 secs, then start and leave to idle for 3-5 mins. If this doesn't work yo may need to get the idle actuator reset then repeat the throttle reset.
Make sure the electrician you use realises this is a '98 Alfa as not all diag systems work .. some return codes, but are meaningless. You really need to hook it up to Examiner, which is an Alfa/Fiat diag system or AlfaDiag which is a DIY system (about £50). Unidiag may also work (free). You'll need a laptop and a VAG-COM KKL interface cable for Alfadiag and unidiag.
Been looking through the service and repair records
at the 48,000 service- Investigated reported surge when idling, cleared out throttle pot, and reset idle actualator
Then a later service (with no date or mileage, alfa romeo cheltenham)- Roadtest for idle fault checked on examiner, cleaned out throttle body and reset parameters, checked examiner imobilisor fault identidyed- new keybox required.
Then is 2006 new electro valve part no 71713829 (idling unit) was replaced.
I wonder now what it could be as most of the likely candidates have been done. Ill have to wait and see what the motor lecky brings up. Hopeing its just needs recoding or something
Anyone got any ideas on how this info changes things?
1 - 12 of 12 Posts
