Maybe your battery is bad, also could be the alternator, or some wiring.
Start by checking the voltage on the fuse, behind the ICS... I think the ICS turns off when the battery is low. You should get around 14.4V when the engine is runing, and 12.5-13V, when it's off.
the battery is new, when winding the machine voltage of 14 V exactly.
Hi Sergey, The bootload is looking for an update. What year is the car Does it have sat nav.Have you updated the sat nav disc.
So IF I get you right It works OK with ignition just switched on but is muted when you start the car.
Pomeo
Pomeo
Hey, yeah, it shuts down when you start it, and sometimes it can work.
Discussion Starter #7 (Edited)
Pomeo
cd changer is disabled and navigation is disabled, navigation does not work in our country, disk emulator is connected, this is the case in the radio
