I want to build an 11.5:1 compression, 8000rpm Busso :devious:
It must look stock (No ITB's but larger throttle, plenum and MAF is planned)
It must be N/A (no turbo, no supercharger)
It must be as reliable as a daily runner
Must be prepared to accept a sequential 3 stage NOS kit (50kW; 75kW; 100kW stages)
The build will be a long term project as I only have around R3k per month (if I don't have other expenses to cover for that month). I want to do:
Planning
Sourcing
Machining
Assembly
Installation
Commissioning
Planning:
How do we do this?
What do we need?
What would be the best sequence of events to follow?
Additional enhancements other than engine? (clutch, brakes, fuel pump, drive shafts?)
Sourcing:
Which parts do we need to buy
Where to source the required parts from
Machining:
Cams
Valves
Crank
Balancing
Headwork
Assembly:
Installing all components and building the engine
Commissioning:
First start
Mapping
Dyno
Nos commissioning
Mapping
Dyno
Anyone know where to start? And how do I do this? :yes:
Planning
Sourcing
Machining
Assembly
Installation
Commissioning
Planning:
How do we do this?
What do we need?
Sourcing:
Machining:
Cams
Valves
Crank
Balancing
Headwork
Assembly:
Commissioning:
First start
Mapping
Dyno
Nos commissioning
Mapping
Dyno
