1 - 20 of 52 Posts
J
My new 156:cry:
So, I'm on call this weekend so time is scarce. I needed to get new rubber on and get back in time to field the first wave of service calls at about 11am. This was done along with a quick wash with about 10minutes to spare:cool:
The first service call was in Navan so I thought, happy days, quick call then back home to enjoy the sun. I know, I'll take the 156. I threw my tools and a few bits in the back on headed off.
From Navan I had to go to Delvin across the N51 where I was behind an MPV of some description, it slowed to a crawl so I dropped a cog and booted it. This is where it went wrong, it would appear the car slowed for an uneven road surface and by the time I realised what was going on the (lowered) suspension bottomed out heavily twice in quick succession. It probably didn't help that I had all my tools in the back awell:rolleyes:
The problem I now have is that the steering feels a bit vague but the main thing is it now gets a shimmy under acceleration between 50/60 and 80/100 ish, ease off the throttle and it fine, power down and the shimmy comes back.
I wonder have I bent something, buckled an alloy or two, or just thrown a weight from a wheel? I had no time today but I'm going to swap the wheels front to back to see if it makes a difference, that and while its jacked up see if anything looks a bit wayward.
I don't believe this, I'm absolutely loving my new car and I have ruined what I liked most of all, the handling:cry: really hoping this is a hiccup as opposed to acid reflux:vomit:
Anyway, a couple of pics I made this morning before I broke it:eek:
J
Me too man but google is telling me CV joints...
I'll know more tomorrow, did you get sorted with a door lock? And so it begins as they say...
:lol:
I would get the wheels up to BC engineering in Beechmount Ind Est Navan. They can check out the wheels if this is the problem. My Ti front wheels are soft alloy so need to be straightened every year by them. They do wheel restoration too. I plan to bring the wheels of the spider to them in the next couple of weeks... 30 quid a wheel to straighten last time I was there and they do a great job
Oh no....
That's a shocker altogether, I really hope its nothing too serious.
The handling was my favorite thing too, damn that car knows how to take a corner!
I miss it actually, I'm starting to regret selling it, trying to replace it is not an easy task at all.
J
Right, quick update.
I had both the front wheels off today and BOTH outer cv boots are split, I've never seen them split like that after bottoming out but such is life, lesson learnt and all that.
With the wheels back on, I took it down the road (gingerly) and the shimmy between 50/60 is all but gone so I can only imagine that removing the wheels jacking it up, re seating the wheels and letting it back down again must have done somthing to settle it. With the spacers on the hub there is very little for the centre bore to sit on so maybe this had somthing to do with it? Anyway there is now a rhythmic knocking when I ease off the throttle aswell so UJ's are definitely shagged I think. :(
The car was going to Ti anyway in a couple of weeks, it will be just having an extended stay now...
I think the term is known as FML...
Anyone have a set of JTD driveshafts they don't need:rolleyes:
J
Discussion Starter #12 (Edited)
Well, I started removing the driveshafts tonight after work but after I'd had a chat with my neighbour and got a 36mm socket off a mate, and had a cuppa, I didn't really get that far.
Front end is up in the air with the wheels off and track rod ends disconnected. I stopped there as I need to get a scissor type ballpoint separator as the fork type one I have is good for wrecking the rubber boots and not much else (add x1 track rod end to shopping list:rolleyes:)
Once I have them off the car the good people of Ti Autos will be refurbing the shafts as I don't want to be doing it twice!
Reckon I'll have it done in time for Classic Car Live?
EDIT @ Davetech thanks for the tip for the wheel place mate, looking at my rims the lad has weights plastered all over the place so a once over wouldn't hurt I think.
J
So, this evenings fun involved removal of the driveshafts. I left the cups in the gearbox as I had a good feel around and they feel nice and smooth on the inside, that and I couldn't get them out:lol:
Carrying on from yesterday I got a proper ball joint separator from halfords and removed the other track rod end and the ball joint on the two upper wishbones (no damage to rubber boots:thumbs:). With those removed its possible to tap out the splined shaft from the hub and remove the driveshaft complete with spider but with the cup still attached to the gearbox.
To get the cup out I read in a couple of other threads that you can attach a pair of mole grips to the cup with the spider in place and use the driveshaft as a kind of slide hammer to get it out, when I tried this the grips just kept sliding off the cup. Another method I read was to tie a rope around the cup (with the shaft removed) and twist a stick round and round until it popped. When I tried this I used a tow rope and a ratchet strap fastened to the 33, all this did was drag the 33 along the drive! So, I gave up.
One thing which was odd is that it looks like water has gotten into the inner CV boot as the grease has gone rusty looking and a bit emulsified, no idea how this has happened as the boot is in tact and the bands were nice and tight.
So now I have the shafts tucked away in my van hoping that I will get a job in Dublin tomorrow so I can drop them into Ti autos. I'm REALLY hoping that the outer joints are ok and just need new boots putting on but tbh I think at least the passenger side one is buggered. The two spiders are also completly knackered with lots of play in the bearings.
Y'know, on the one hand it sucks that the shafts have gone having just bought the thing but I am actually quite enjoying pulling the thing apart, I have the right tools and am just taking my time with it. I took a few pics of my progress, I'll try and upload them in order...
Well chin up as they say :)
You are doing great progress, and the knowledge and skill you acquire will help you forever.
And you will get your Alfa sort in progress.
You will get it back on the road yet.
Jim, sorry to hear of you trials and tribulations!
How much was the ball joint separator as a matter of interest?
(Writing as one who has the 'tuning fork' variety and has wrecked rubbers before too!)
J
Discussion Starter #16
Thanks man, well it wont be on the road this weekend anyway as my new cv boots have not yet arrived at Gerrys, Damn postal service... To be fair gerry offered to fit spurious items but advised the proper ones are better. I don't plan on doing them again for a while so proper ones it is!
It never stops does it Rory? I was stuck so bought from halfords, 29.99 it was, its ok for my needs anyway. The only problem is its not big enough for the bottom ball joint but the only time you need to take the lowers off is for replacement so th fork type would suffice.
Thanks Jim and all the best with getting your bella sorted.
J
Discussion Starter #18
No worries, should be back up and running by Tuesday with a bit of luck.
Any ideas why I can't upload pics anyone??
Administrator
No problem here posting attachments from a PC using IE, are you getting any error messages ? Are the pics the within the size limits ?
J
Discussion Starter #20
I didn't see any error messages David, normally I just click upload and off they go.. Tried from my phone, iPad and desktop pc last night with no luck. I have a photobucket account just can't remember the login details, wil have a go with that tonight...
1 - 20 of 52 Posts
