i have a rattle,creak, tapping noise coming from what sounds like the dash, just below the windscreen above the passenger airbag. i cant find anything loose and bizarrely it only does it when im turning left:confused: it doesnt sound like suspension or steering though because it sounds as though its this side of the bulkhead, any ideas?
ive checked the obvious like loose trim around the windscreen or the wipers.
the windscreen itself doesnt feel loose but im wondering if its moving when i have left lock on, maybe the shift in weight when corning is enough for the windscreen to shift everso slighty and make this noise. its very hard to pin down where exactly the noise is coming from.
it doesnt sound like a trim creak, its a deeper sound than that.
Its not the sprung 'pocket flap' on the dash console :confused:
Ours used to squeek until I eventually found the noise and lubed it
Top suspension bush (wishbone) is known to sound through the bulkhead / dash.
...that's called a wife :D
god that sounds expensive:rolleyes: ill pop into northantsalfa and get them to have a look see.
Don't panic, it's not. One of the cheaper suspension part TBH.
