Alfa dem:
There is no sorcery in how most people here are getting the mileage they are. In the case of Andyroo75, that's to be expected. Nine litres is basically two gallons (4.54 litres / 1 gallon), so him managing twenty miles on two gallons is no surprise, is it?
If you cannot manage over 200 miles on a full tank of decent fuel during "normal" driving conditions then may I suggest these:
1. Check your tyre pressures: if you're running the standard 205/16 or 225/17 then the pressures are: Front 2.7 (39 psi) - Back 2.5 (36 psi). Incorrect (low) tyre pressure is probably the main cause of bad fuel economy, and it quickly knackers your tyres!
2. Check the Lambda probe/sensor is operating correctly and also the integrity of the connecting wires. A Lambda can appear to be working fine but actually be relaying wrong information, thus giving you terrible fuel economy.
3. Check that spark plugs and air filter are optimal. Either - especially a dirty air filter - can have an adverse effect on fuel economy.
4. Turn off the A/C. If you have it turning on automatically when starting the car then there is a short guide in the manual showing you how to turn this "feature" off. If you don't have it PM me and I'll reply with it.
