1 - 14 of 14 Posts
Carefull after having a good curry !
I have studied this photograph carefully, and have come to the conclusion that not everything is as it seems.
The gentleman in the over-casual attire is bending over, (in a sordid flatulence emitting stance), very much in the foreground.
Note, if you will, the flamethrower in the background, which is actually responsible for the flames.
You could be forgiven for believing that the flames are actually exiting the gentleman's rectum, but I am well trained in observation, and must point out that by way of a strategic pose, you have been fooled into a false view, vis a vis the possible after effects of the consummation of a spicy repast.
Yours
Victor Mature.
It does appear as if he has two sphinter's as he is emmitting a double barrelled rectal burner.:eek:
Indeed.
Also, the higher "spurt" is located higher than a regular rectal position, being as it is somewhere in the environs of his coccyx.
1 - 14 of 14 Posts
