How do you know when your remap is working?
In about a month's time I want to take my GTV for a remap. Trying to "calculate" or "Figure out" how much power can be expected is driving me nuts, since I like to know how things add up and they have to add up in order to make sense to me. (Consider: I intend fitting a Dastek UniQ-4, which is a mapable ecu rather than map my own ecu).
I know a remap doesn't make power from nothing. On a NA engine, it works if:
1. Timing needs to be adjusted.
2. Fueling needs to be adjusted.
That's it. And anything that affects timing and fueling will need to be compensated for: Different cam, some head work, free flow exhaust, free flow air filter, etc. Basically you want as much air going into the engine as possible (mechanical work will help for this in NA cars) then you want your fuel to burn at the right time to release as much power as possible. That means adding as much fuel as the air will burn, at the right time and igniting it at the right time (software will do this). That is what the remap will do for you.
To make my question more clear, I would like to know (since the map will be looking at flow values from the MAF and injectors) does anyone know what these values should be? I can get values from MultiECUScan but obviously my car isn't stock and I am looking for stock values?
