P
I have downloaded the alfa part cd, from alfa75.org. i dont know how to make it run?
Is thre someone there could help me?
Once you have downloaded the CD you need to actually burn it to CD using a CDR drive. This is part of the copy protection. Although I haven't tried, I suspect any of the CD emulators would work with it as well.
Let me know if you have any problems.
Cheers,
alex
P
I have burnt it on a cd. When i try to start it, it starts in a setup window to choose country. and i can't do anything else..
Hi Guys,
From what I can remember I just picked the appropriate country and it then installed the viewer software. Once that was done I could then use it to browse the CD.
Does the installation routine not work on your computer?
Alfaowner - I can't remember exactly how much data is on the CD but I'm sure it's a few hundred meg. I'll check.
Hugh.
P
as a zip file 186 mb. and unpacked it is 352 mb
You have to make sure that size of your fonts is set to "small" or "normal" in display properties. Also, old versions (at least, don't know about more recent ones) work normally only under win9x, not NT or W2K.
