1 - 2 of 2 Posts
Hi All
Can anyone help with a how to guide to replace my clutch ?
I have purchased a NEw clutch kit from Valeo and my mechanic in Australia will help with the install ,He has not worked on Alfas so would like a guide if possible.
Do we need to remove the engine and box to replace the clutch?
Any help greatly appreciated
Regards Dave :thumbs:
L
remove battery, the tray & the 2 drive shafts, open 3 13mm bolts off starter, another 6 18mm/19mm headed bolts, 2 13's & your almost there, the rear & front gear box mounts need to come off too. the secret is to remove the threaded studs from the rear of the gearbox in order to allow the gear box to turn thro 90 deg's before removal, otherwise you'll need to drop the sub frame.
1 - 2 of 2 Posts
