· Registered
Hi Alfa Lovers
I'm in need of some assistance to allow me to remove the cylinder head of a alfa romeo 147 twin spark, 2001.
Could anyone, please send me some instructions or a how to guide. I would highly appreciate any help. I am looking for some advice/instructions on the valve time settings as well.
Thank you.
· Premium Member
yep what iainfm said. Cam locks, belt tensioner and a gauge really at a minimum
· Registered
Discussion Starter · #6 ·
Thanks to everyone who helped on my question.
Car is now starting up but the following problems are occuring:
There is very little, i mean very little power
The car does idle, but there is a slight misfire
If the car idles for longer than 15 minutes and I turn it off, the car will not start again immediatley
Only after 30 minutes or so will I be able to start engine
Any and all help would be highly appreciated.
· Registered
The not starting for 30-minutes may point to a failing crank sensor.
As for the lack of power, did you use the correct cam locks and follow the correct procedure for tensioning the belt?
· Registered
Discussion Starter · #8 ·
Tried a different crank sensor but still giving me hassels, will have to get a new one, just to be sure.
cam locks and corrrect procedure for tensioning the belt. Could you please advise how this should be done...
Thanks David C
