I had to change the N/S/F caliper and the reservoir went dry. I bleed all 4 corners with new fluid until all air was out. O/R, N/R. O/F and N/F. is this the correct sequence for a UK Alfa Romeo 156 2.0 JTS 2005?
I have brakes but they feels spongy with too much pedal travel. So I think I have introduced air into the abs module.
Anyone know of the correct procedure on how to use Fiat Multiecuscan to correctly purge the ABS of air and in what order to re-bleed the braking system again?
Or do you know of a tutorial that explains how to purge the ABS of air and correctly re-bleed the braking system that I can follow please?
Thanks for any help
Thanks for any help
