161 - 163 of 163 Posts
you are OK on all, go to 90 straight.
Update to 90 was successful! Thanks!!
(but not without some hiccups)...
Upon initial attempt, after the USB data validation step I received a message: Installation File Integrity Error
I tried with both the 90 and 85 updates using a 16GB flash drive formatted NTFS
I tried again using a different flash drive (4GB, NTFS) and it worked flawlessly.
Maybe the Magnetti Marelli system is temperamental with some flash memory hardware?
So, if anyone else gets that error message, try with different USB flash drives.
Discussion Starter #162
Good that it worked in the end.
No idea about usb fash drives. There have been 1 or 2 other people who've needed to use another usb stick to get it working....
Initial Full NTFS format (in stead of quick format) also seems to help sometimes.
Save the drive you now know works ;)
I use a Sandisk 16 Gb USB 3.0 flashdrive myself, which is (obviously) faster then a 2.0, formatted NTFS under Windows 10, . Never had any problems with this.
Updated to .90 successfully. Thanks for sharing
cheers
