Remark: Updated version , date 16 November 2020
Information on updating maps and software for Giulia/stelvio infotainment system
Note that systems and software are same for giulia and stelvio, so same procedures apply.
There are currently 2 hardware versions of the infotainment hardware covered here, one from approx 2017 and earlier (old system), the other (newer) introduced since then (intro new around Nov '17 Europe, July '17 USA). Maps for these two systems are the same, other then distinction between 8.8" maps and 6.5" maps for Europe. Correct maps will automatically be presented on map download site based on entered VIN
Note: Completely different are the latest MY20 2020 facelift model(s) having different hardware again, so different firmware, as well as maps.
The following descriptions here concern the 2017-1019 systems, 2020 systems and later are (not yet?) covered..
So take note that "old" and "new" systems in the following text relate to the 2017-2019 models, not the latest MY20 model.
The functionality of the 2 original systems is the same, but they use different processors and internal circuitry, and so require different firmware.
The new system appears to be about twice as fast as the old system.
Another difference is that new systems can have Apple Carplay/Android Auto, old systems are not capable of this.
Easy way to see which system you have is by looking at the firmware version via the system menu.
<settings> <system> <software update> <current version>
The "old" firmware is numbered 001.xxx.xxx, 002.xxx.xxx etc., the "new" system is numbered with higher numbers in front, such as 051.xxx.xxx, 056.xxx.xxx etc.
Starting with 056.xxx.xxx support for AA/ACP was added (though not automatically activated).
The firmware versions
cannot be exchanged, so for firmware updates the correct series software for the installed hardware must be used. The system checks for compatibility at update.
Initialy firmware versions were available as download from Alfa for updating, however, at some point Alfa closed this update path. There are however still early versions circulating on the internet. A number of these were collected and are available via the bottom on this posting.
Official update route for firmware is via the dealer, maps via user.
Latest version for the old hardware (in Europe & NAFTA) is currently 002.010.041. For Australia (new Zealand?) there is a 002.009.056 version that solves the voice recognition problem they had (now also 002.009.061?). For Nafta there is a version 002.009.059, which solves reboot issues with satelite receiver. Note both these last versions are not compatible with Europe.
Early versions such as 001.xxx.xxx were not yet suited for user map updates, and
require updating to at least 002.xxx.xxx to enable map updates.
Firmware for new hardware is still continuously evolving (situation beginning 2020) ....
One of the early versions was 051.xxx.xxx, other versions (examples) 056.000.007, 072.001.002, 081.000.004, 085.000.046, 090.000.061, 119.001.009 etc.
Apparently updating past 072.xxx.xxx from earlier versions to later also requires checking if following modules are at sufficient software version, and these might require updating.
- AMP (Amplifier HiFi system)
- BSM (Brake System Module)
- IPC (Instrument Panel Cluseter)
- PAM (Parking Assist Module)
- LBSS/RBSS (Blind Spot Sensors)
- BCM (Body Computer Module)
This needs to be done by dealer as this requires the dealer tool Witech2. See also
info file 085 update.pdf in the downloads.
Map updates (in Europe) can be downloaded from the Mopar website after registering, as they require a license file for installation, based on the VIN of the car.
Since July 2020 there is also a NAFTA FCA website for NAFTA map downloads. On this site select "3D CONNECT NAV" for early models, and "3D CONNECT NAV MY20" for the new facelift 2020 models.
Officialy maps are free the first 3 years after car registration. After this period you can buy an extension for an additional 3 years via the dealer.
Original supplier of the maps is TomTom, new maps come out every 3 months. There is a difference in maps for the 6.5" systems and 8.8" systems, the correct (latest) map for your car should automatically be presented on the Mopar site upon registering with your VIN.
Update procedures:
Firmware
Note that firmware versions in principle do not need to be loaded sequentially. You can directly load the required (most recent) version.
Preparation
Format a 16 GB USB stick (max 64 GB) as NTFS. Note that MacOS extended, as mentioned as option for map updates, seems to give more problems with firmware updates, so Windows NTFS is recomended for firmware updates.
Download the correct version for the installed infotainment hardware. This is usually zipped.
Unzip the file, this should give a .bin file, a .xml file and possibly a .md5 file.
- place all unzipped files on root of USB stick
- place stick in USB port car. Don't use usb port in rear, as this is power only
- make sure there are no other devices in any of the other USB ports
- start engine and switch off auto start/stop, do not drive.
- select <settings> <system> <software update> <update software>
- update should start, takes approx 15 minutes. System will reboot once or twice during update, internal fan will switch on
- after completion, remove usb stick
Maps
Note that map versions in principle do not need to be loaded sequentially. You can directly load the required (most recent) version.
Preparation
Format a 16 GB USB stick (max 64 GB) as NTFS. On Apple it seems MacOS extended (journaled) also works for maps.
If first time in Europe, create an account on Mopar website. Download license file and map file
Download sites for MAP files:
Europe:
maps.mopar.eu
or
NAFTA:
Maps FCA NAFTA
This should give 2 files, a .dct file (license) and a .bin file (map)
- place the 2 files on root of USB stick
- start engine, switch off auto start/stop
- select <settings> <system> <maps update>
- update should start, takes approx 70 minutes on "old" hardware, 30 minutes on "new".
Note: the system will tell you it will take much longer, this is incorrect though, the above times are approx correct
Update should be started whilst car is stationary. After update starts to run, car can be driven during update. Do not switch off engine during the update, as this will cancel the update.
Special remarks on early version 001.xxx.xxx firmware
001 was the first version of the infotainment firmware for the "old" system.
This did/does not support user updates of the maps via USB yet, it does however support
firmware updates via USB.
To be able to use the option to update maps, and solve a number of bugs, it is recommended to update to the last version 002.010.041.
Also note the navigation was improved with version 002.
This update can be done with the standard procedure above. However, updating from 001.xxx.xxx
will delete the existing installed maps and possibly onboard manual. This is not a problem, as after the update to 002.xxx.xxx you can subsequently install the latest maps, and if required, the onboard manual. Just takes a bit more work first time
=============== DOWNLOADS ===============
Unofficial download location 002.009.055:
M86.zip
Unofficial download location 002.009.059:
M88_U2_17094C_19034A_GU_MY18.zip
Unofficial download location 002.010.041:
ETM_SW-002.010.041.zip
Relevant Service News File:
ETM_MV_002.010.041.pdf
Unofficial download location 056.000.007:
A56.zip
Unofficial download location 085.000.046 :
A85.zip
Relevant Service news file:
Unofficial download location 090.000.061 :
ETM_SW_A90.zip
MV_090.000.061.pdf
Unofficial download location onboard manual M72
M72.zip
Note: not sure if the manual will install, as according to enclosed config file it's originally for firmware 002.009.047 and has an expiration date of 2018-12-31
Additional note: A workaround for the above has been found by "fooling" the system as follows:
- disable time/date GPS update in system setting of infotainment
- manually set date/time to an earlier date then 2018-12-31, f.i. June 2018 (example)
- Perform the update
- upon completion re-enable GPS time/date
info 002.009.055
service bulletin 08-002-18
info 002.010.041:
info 002.009.059
service bulletin 08-013-19
