1 - 13 of 13 Posts
Get an old sheet and get 2 on the front seat.
I have never seen the boot on your motor but couldn't you tie it down if the lid won't shut.
iv transported wheels before i put 1 in the boot 2 on the back on an old sheet and 1 on the front seat too! its a squeeze but it can be done! :thumbs:
yeh i got 17" with tyre in just, autochanger took a bit of a battering but its going anyway. u could easily remove it tho.
Two in the back side by side and two on the passenger seat on top of each other! Just get some dust sheets!
Good luck!
With these wheels,if the offset is,for arguments sake 38,would a 10mm spacer make these equivilant to 28 offset?Thanks
If i need to use a 10mm spacer,what lenght bolts will i need?And what size are the bolts i need?
Hehe - had to do the same when I had a set of tyres delivered to work by mytyres. Accompanying odour of new rubber got quite overpowering on the way home...
1 - 13 of 13 Posts
