1 - 2 of 2 Posts
I need to drain my selespeed fluid as it has gone milky. I understand this can done by disconnecting the bottom pipe on the resvior, however I need to know if the system will then require bleeding and if so how this is done?
Any help will be much appricated.
Thanks Luke
L
you need to make sure that the system has de-pressuired over night, so disconnect the battery, then in the morning remove the battery & battery tray, then open the return pipe [ softer of the 2 ] from the actuator to the reservoir. be sure to collect the fluid. you may need to repeat a 2nd time or let it drain into a bucket for as long as possible, consider flushing out with new oil too before putting it all back together.
once oil is in the system & you select gears the system will self bleed.
1 - 2 of 2 Posts
